    Thursday, November 5, 2026 4:45:31 AM
    Looking for a Motor and Gearbox Setup for 30mm Shaft
    7 months ago
    Hello, we have an application where we need to drive a 30 mm shaft using a 90VDC motor with adjustable speed. I came across a setup on your website that looks close to what we need (motor + gearbox configuration).
    Main requirements are:
    1. Gearbox with a female 30 mm through bore (6 mm keyway)
    2. Around a 1/2 HP DC motor
    3. About a 60:1 ratio, targeting roughly 720 in-lbs torque
    4. A speed controller with heat sink and a manual control knob
    5. Height from base to shaft center: about 55 mm
    Is this something ATO can supply, or does ATO have a similar setup?
    7 months ago
    Sorry, we do not provide 90V DC DC motor.
    Can you use a DC worm gear motor instead of this solution?
    We recommend a 450 W DC Worm Gear Motor (12V/24V/48V), SKU: ATO-GEAR-W450.
    You can check the specifications here: https://www.ato.com/450-w-dc-worm-gear-motor
