    Thursday, November 5, 2026 4:47:55 AM
    Brake Selection for Dyno Use in Variable Temperature and Humidity
    Hello,
    I’m putting together a small motor dyno, around 15 Nm, and trying to figure out what kind of brake makes sense. The setup isn’t in a climate-controlled lab — temps will be roughly -5°C to 45°C, plus some humidity swings.
    Was looking at a magnetic particle brake at first, but now I’m also eyeballing the FBD-1 and FBD-2 electromagnetic series.
    Couple things I’m stuck on and hoping someone here can clarify:
    1. What’s really the difference between ATO FBD-1 and FBD-2 besides how they mount?
    2. Are these spring-engaged / power-off holding brakes, or can they handle continuous dynamic loading?
    3. ATO FBD-1 mentions “high frequency operation and slight movement” — what’s that even mean in real-world dyno use?
    4. ATO FBD-2 says it’s good for wet/dry environments — how does that deal with actual humidity swings?
    5. What’s the full operating temperature range?
    Basically trying to figure out if a friction-based electromagnetic brake will behave predictably in my setup, or if I should be looking at something else.
    VENUS wrote:
    Hello,
    VENUS,
    1. SKU: ATO-EB-FBD1, Static Torque * 15Nm, https://www.ato.com/electromagnetic-brake-15nm
    2. SKU: ATO-EB-FBD2, Static Torque * 15Nm, https://www.ato.com/electromagnetic-brake-25nm
    The main difference between FBD-1 and FBD-2 is forward vs. reverse installation. Neither FBD-1 nor FBD-2 is recommended for humid environments — friction plates will swell when exposed to moisture. Operating temperature is fine for your range: min -20℃, max ~60℃.
