    Thursday, November 5, 2026 4:48:00 AM
    Load Cell with Display for Arbor Press Monitoring
    9 months ago
    I’m putting together a simple force monitoring setup for a manual arbor press, and I wanted to sanity-check my parts list before placing the order.
    I’m examining the ATO-LC-TC01 tension/compression load cell and pairing it with the ATO-DPM-LC5D display/controller to display the applied force while pressing.
    Has anyone used this combination before? Are these two units directly compatible with each other?
    Do I need anything else in between (signal amplifier, transmitter, etc.), or will the display drive the load cell on its own?
    The goal is just a live force readout and maybe using the alarm outputs later for max-force limits. No PLC or automation planned.
    Appreciate any input before I pull the trigger on this.
    9 months ago
    Patton wrote:
    Hi, Patton
    ATO-DPM-LC5D is compatible with ATO-LC-TC01. With both, you will have a load cell and a display with 2 alarm outputs.
    Just note:
    1. ATO-DPM-LC5D requires a 100–240V AC power supply; you need to find a plug with wire leads to power it.
    2. ATO-LC-TC01 has a 2-meter cable; you need to confirm whether that is enough for your mounting.
    See specs, price, and you can order online by credit card on:
    https://www.ato.com/tension-and-compression-load-cell-1kg-to-200kg
    https://www.ato.com/5-digit-display-controller-for-pressure-sensor
