    Thursday, November 5, 2026 4:47:58 AM
    Diaphragm Pump with VFD for 24h Slurry Service
    9 months ago
    I’m an engineer in Fairbanks, Alaska. We’re looking to source a 3" diaphragm pump with a frequency converter (VFD) for continuous 24h operation on a soil processing plant.
    I found a pump on the ATO website that appears to be suitable. Still, before committing, I wanted to see if anyone here has experience with similar slurry applications or thoughts on electric vs. pneumatic diaphragm pumps for continuous duty.
    Any feedback or lessons learned would be appreciated.
    9 months ago
    Kevin wrote:
    Hi Kevin, we need to know whether there is particulate matter in the pumped medium.
    1. How big are the particles?
    2. What material is used for the pump body?
    We just need this information so we can recommend a suitable pump and frequency converter.
    9 months ago
    Any feedback or lessons learned would be appreciated.Hi Kevin, we need to know whether there is particulate matter in the pumped medium.
    Hi! It’ll be used for pumping a slurry of sand and fines, about #140 mesh.
    The pump will be installed between our clarifier and thickener tank, moving roughly 20 tons per hour of material.
    9 months ago
    Ok, we can provide two options:
    Electric diaphragm pump: Maximum flow rate: 14 tons per hour; Diameter: 4 inches
    Pneumatic diaphragm pump: Flow rate up to 20 tons per hour; Diameter: 2 inches
    Which option would you choose?
    9 months ago
    The pump will be installed between our clarifier and thickener tank, moving roughly 20 tons per hour of material.Ok, we can provide two options:
    Could you please provide detailed specs for the 4" electric diaphragm pump equipped with VFD?
    9 months ago
    Which option would you choose?Could you please provide detailed specs for the 4" electric diaphragm pump equipped with VFD?
    We recommend an electric diaphragm pump with the following specifications:
    Flow rate: 0–16 tons per hour
    Lift: 0–30 m
    Suction lift: 0–3 m
    Maximum outlet pressure: 0.3 MPa
    Pump material: Stainless steel
    Diaphragm: Teflon (PTFE)
    Maximum particle diameter: 7 mm
    For the VFD, we recommend GK3000-4T0075G, input voltage 380V: https://www.ato.com/10hp-vfd
