    Thursday, November 5, 2026 4:52:20 AM
    Digital Counter Recommendation for 24V DC Flow Meter
    10 months ago
    I’m working on a project that uses a 24V DC flow meter, and I need a digital counter to count the pulse output from the flow meter.
    The digital counter should be compatible with 24V DC signals and suitable for industrial use. Does anyone have a good recommendation? Thanks in advance.
    10 months ago
    Hi Jasper,
    For your 24V DC flow meter application, we recommend the ATO-DIGC-FH4-4CRNB digital counter, support 24V pulse input, see spec on: https://www.ato.com/digital-counter-4-digit-up-down
    10 months ago
    Hi Jasper,
    I’ve used the ATO-DIGC-FH4 counters before with turbine and electromagnetic flow meters. They work reliably with 24V pulse outputs and are easy to wire. If your flow meter output is an NPN or PNP pulse, this counter should handle it without any issues.
    10 months ago
    The ATO-DIGC-FH4-4CRNB sounds like exactly what I need for my 24V DC flow meter.
    Really appreciate the help!
