    Thursday, November 5, 2026 5:38:20 AM
    30 hp Soft Starter Error 06 and 16
    Hey everyone,
    We bought a GS-022 soft starter (SKU: GS-022) earlier this year and ran into two shutdowns this week. First time it threw Error 06. We checked the voltage on L1, L2, and L3 – all within 1% of each other. Hit the reset button, and it worked again.
    Then this morning it stopped again, this time with Error 16 (8-10 open). The problem is that we didn’t receive a manual with the unit, so we weren’t sure how to troubleshoot it.
    Has anyone run into this before?
    Voss wrote:
    Hey everyone,
    Voss, please see the attached user manual.
    For error code 06, please check if there is a problem with the motor cable and motor wiring first.
    If you confirm that the cable is not loose and the motor is wired correctly, please set FC=2, FL=0, and test again.
    Please also use a clamp ammeter to measure the output current during soft start operation to see if it is normal.
    If you still have problems, please provide us with a video for further confirmation.
    Hey everyone,
    Has anyone run into this before?Voss, please see the attached user manual.
    +1 on what ATO said. We had Error 16 before, too – turned out the jumper between 8 and 10 was a bit loose. Tightened it up, and the unit worked fine after that.
    Oh, it turns out that terminal 8 is a bit loose! I re-tightened all the connections, and the soft starter is now running perfectly. Appreciate the help!
