    Thursday, November 5, 2026 5:32:02 AM
    Help Choosing Load Cell and Display for Engine Valve Spring Pressure Tester
    I'm having a problem with one of my tools — an analog engine valve spring pressure checker. Think of a 1-ton arbor press with a dial gauge (reads up to 1000 lbs) mounted on the bottom platform. I'm using it to compress valve springs (up to 1-3/4" diameter) to a specific height to measure and balance spring pressures.
    I'm looking to upgrade to a digital setup. So far, I'm considering these load cells and display from ATO:
    ATO-LC-P01
    ATO-LC-TC03
    ATO-LC-P02
    Paired with the ATO-LCTR-OAR digital load cell amplifier.
    I’d like to adapt this setup to my press. I'm still a novice with load cells and digital measurement tools, so any guidance would be greatly appreciated, especially regarding installation and compatibility.
    Thanks!
    Edward wrote:
    ATO-LC-P01
    ATO-LC-TC03
    ATO-LC-P02
    Thanks!
    Hi, Edward!
    If your press is capable of applying up to 1000 lbs and you're using it to measure valve spring force, then yes — you're on the right track.
    Among the options you listed, the ATO-LC-P02 tension/compression load cell would be the best fit. It’s more suitable for your application and generally easier to install under a press setup like yours. It handles both tension and compression forces, which is useful for your vertical compression test.
    Pairing it with the ATO-LCTR-OAR digital display will give you real-time readings and improve accuracy over the analog gauge.
