Saturday, April 5, 2025 6:12:59 AM
How to Control the Brake with BLDC Motor Controller?
#250 Quote
Hello, everyone! Can you help me with the next questions about the BLDC motor controller ATO-BLDC-KBL?
1. Can I use an external power supply (24 VDC) to energize the controller?
2. How do I wire the brake to the controller?
3. Do I need to signal one of the 14-pin connector to enable the brake? If so which pin and what type of signal (24V, 5V, etc.)?
#251 Quote
Hi Daniel,
For your questions,
1. No, the power supply of your controller can only match the voltage of the motor you purchased. In other words, if the motor you purchased is 48VDC, the input voltage of the controller should also be 48VDC, not 24VDC.
2. Regarding the wiring of the controller, you can use the 1#PWR in the 14-pin connector to connect to the B+ terminal through a push button switch as the control signal of the controller. Please refer to the attached drawing.
3. The control voltage of the brake is 24VDC. It can't be controlled by a controller, you can only control it individually through an external 24VDC voltage.
#252 Quote
Hi Daniel,
For your questions,
1. Is it ok if I put a contactor in the B+ terminal?
2. Does the brake have to be active all the time the motor is stopped?
#253 Quote
1. Yes, you can put a contactor in the B+ terminal and 1#PWR cable.
2. The brake will be activated as long as the 24VDC power supply is disconnected. You can release the brake while the motor is running and activate the brake when the motor is stopped.
