    Friday, January 3, 2025 11:20:05 PM
    Recommend a Suitable Pressure Sensor for Feeding Pipes
    2 months ago
    #241 Quote
    Hi everyone!
    We're working on a project to detect congestion in industrial feeding pipes. These are 75mm bendable pipes used to transport food/feed particles. We're considering using a pressure sensor to detect any rise in pressure that could indicate a blockage.
    I found a sensor (SKU: ATO-PRES-P300) that might fit the job. It needs to have an RS-485 output signal. Has anyone used a similar setup, or can recommend any alternatives?
    2 months ago
    #243 Quote
    Lovegreen wrote:
    Hi everyone!
    Hi,
    If you're looking to use a pressure sensor to check for blockages, it's essentially about measuring the air pressure within the pipe. You'll need to determine the threshold pressure level that indicates a clog. Once you have the measuring range and installation method figured out, you can test with our pressure sensor.
    2 months ago
    #244 Quote
    Lovegreen wrote:
    Hi everyone!
    Hey,
    I've worked on a similar project. Instead of a standard pressure sensor, we used a differential pressure sensor. It helped us monitor not just the absolute pressure but also the pressure drop across sections of the pipe. If the drop was too high, we knew there was a blockage. Just a thought in case you're open to alternatives.
    2 months ago
    #245 Quote
    Thanks, ATO and Sailar! Appreciate the quick replies and suggestions.
    I assume the pressure inside the pipe won't reach anywhere near 100 kPa (1 bar), so I'll start with this sensor to get some baseline values. If it goes beyond that, I can always upgrade to one with a higher range.
    @ATO Support: Could you clarify the wiring for the RS485 version? Maybe provide an image showing the colors of the wires? Also, do you have any info on the average lifespan of these sensors?
    2 months ago
    #246 Quote
    We've used the ATO pressure sensors in our facilities, which've been quite reliable. The RS485 wiring is pretty straightforward if you follow the manual, but it's always good to have a clear diagram. One thing to consider, though: if you're working with food particles, keep an eye on maintenance. Residue buildup can impact sensor accuracy over time, so regular cleaning might be necessary.
    2 months ago
    #248 Quote
    Dear, the RS485 version comes with lead wires, typically 2 meters long by default. I've attached a picture for you, showing the wire colors.
    Regarding the lifespan, it largely depends on the working conditions and environment, but under normal use, you can expect around 3 years of service.
    2 months ago
    #249 Quote
    Thank you all so much for all the great advice and tips!
