    Thursday, November 5, 2026 5:41:21 AM
    Choosing the Right Voltage Sensor for 3-Phase Logging
    Hello everyone,
    I’m planning to buy a voltage sensor, but I’m unsure which ATO model suits my application. I need to log AC voltage in a 3-phase system. Should I choose ATO-VOS-AC1000 or ATO-VOS-3AC500?
    Thanks
    Daniel wrote:
    Hello everyone,
    Thanks
    Hi Daniel, we can provide the voltage sensor only.
    1. What is the measured voltage range? Is it AC or DC?
    2. What output signal do you require?
    Thanks for your attention. We have a current sensor from ATO: ATO-CUS-3AC80 [Range 0-80A, Output 0-5V, Power 12VDC]
    We monitor the current consumption of a pump system that normally runs on 400VAC 3-phase, and occasionally on 600VAC 3-phase. The current sensor works great, so now we want to add a voltage sensor using the same setup: powered by 12VDC with 0–5V output.
    I’m also a bit confused about the input terminals and output pins on the voltage sensors. Any help is appreciated.
    Daniel wrote:
    Hello everyone,
    Thanks
    Daniel, we use the ATO-VOS-3AC500 in our industrial pump systems. It’s basically plug-and-play with their 0–5V current sensors. As long as your max voltage stays under 500V line-to-line, you’re good. For occasional 600V events, you might want to double-check the headroom or use external PTs.
    Thanks!
    Both ATO-VOS-AC1000 and ATO-VOS-3AC500 support a 12VDC power supply and a 0–5V output.
    If your pump uses three-phase, three-wire wiring, we recommend the ATO-VOS-3AC500 model.
    Thank you! The recommendations helped a lot, and I’m leaning toward the 3AC500 model now.
