    Thursday, November 5, 2026 5:35:28 AM
    Recommended Load Cell for 275kg Tank Weight Measurement
    Hey, guys!
    I am looking for 4 load cells with a small 1'x1' metal plate on top to put them under a 4'x4'x1' tank at each corner to measure weight change. I want an analog output (4-20mA or 0-10VDC) that can be seen using my DAQ system, which works with LABVIEW. Total weight of the tank with liquid is 275Kg. Please provide a solution.
    Dashiell wrote:
    Hey, guys!
    Dashiell,
    1. We recommend the column load cell ATO-DYZ-101 with a range of 100kg.
    2. We recommend the 6 digit display controller, SKU: ATO-DPM-DY800, with an output of 4-20mA.
    A 4-input, 1-output junction box can be configured to connect 4 load cells at the same time.
    See display specifications: https://www.ato.com/6-digit-display-controller-for-load-cells
    See junction box specifications: https://www.ato.com/load-cell-junction-box
